[Admin] jitsi cert renewal
derjenige der die jitsi Paket install gemacht hat möge das mal bitte fixen:
root@jitsi ~ # certbot-auto
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Broadcast message from root@jitsi (pts/0) (Fri Aug 7 19:15:23 2020):
a
Plugins selected: Authenticator nginx, Installer nginx
Which names would you like to activate HTTPS for?
1: jitsi.ffnw.de
Select the appropriate numbers separated by commas and/or spaces, or leave input
blank to select all options shown (Enter 'c' to cancel): 1
Cert is due for renewal, auto-renewing...
Renewing an existing certificate
Performing the following challenges:
http-01 challenge for jitsi.ffnw.de
nginx: [emerg] "server_names_hash_bucket_size" directive is duplicate in /etc/nginx/sites-enabled/jitsi.ffnw.de.conf:1
Cleaning up challenges
nginx: [error] invalid PID number "" in "/run/nginx.pid"
nginx restart failed:
Fixed.
Danke.
